2000 Chevy S-10 Air bag light on
2000 CHEVROLET S-10
120,000 MILES • 4 CYL • 2WD • MANUAL
CHEVYBOY4LIFE
i have a 2000 chevy s 10 extreme with the 2.2 recently i replaced my flex pipe coming off the manifold because it had a leak in it well while in the process of doing that i noticed there was a wiring harness that was burnt and exposed pretty bad i mean all the wires were touching eachother after following all the wires i found that it plugged in to both abs wheel speed sensors and both air bag crash sensors under the bumper and plugged in to the ebcm my question is is where is my aire bag control module because after replacing the harness with a new one my air bag light will not go off the code says command for deployment but nothing has deployed what dose that mean and what should i do thank you for your time i just really need some help with this
Apr 5, 2009 at 7:27 AM
DOCFIXIT
  • 18,828 POSTS
Module under center consoule
Apr 5, 2009 at 7:40 AM
