2000 Chevy S-10 A/c clutch
150,000 MILES • 4 CYL • 2WD • MANUAL
JAKE1075
How do I change the a/c clutch bearing, or should I have it done by my mechanic. I have some mechanic knowledge, usually I do most of my own work. When it comes to a/c work I am not too savvy on that, other than charging the system up a little. Your input will be greatly appreciated. Thanks Jake
Jun 12, 2008 at 12:37 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:b6a3bfc76a="jake1075"]Air Conditioning problem
2000 Chevy S-10 4 cyl Two Wheel Drive Manual 150000 miles
How do I change the a/c clutch bearing, or should I have it done by my mechanic. I have some mechanic knowledge, usually I do most of my own work. When it comes to a/c work I am not too savvy on that, other than charging the system up a little. Your input will be greatly appreciated. Thanks Jake[/quote:b6a3bfc76a]
You will need a few Specialty Tools which can be expensive for a one time use. I would suggest either taking it to a reputable A/C place to replace the clutch and front seal or take it to a local garage and have them evacuate the system and replace the whole A/C Compressor. Then you can charge the system yourself.
Jun 12, 2008 at 1:40 PM
