2000 Chevy S-10 ABS lights
138,000 MILES • 6 CYL • 4WD • AUTOMATIC
FIXMYRIDE
Abs light and parking brake light come on and off. Brakes also feel like the abs is activationg during normal braking. Previous owner said he would clean a sensor, and the light would go off, but now its back on. Any ideas?
May 22, 2010 at 3:04 PM
HMAC300
  • 48,601 POSTS
there could be aproblem with the abs or master cylinder. when the light is on the ABS doesn't work. if he cleaned a sensor (which i doubt) and fixed it , it's probably because the brake fluid is dirty and needs to be changed badly. have a pro scan this to see what the code is giving. an auto parts store may be able to do this as well.
May 27, 2010 at 7:59 AM
