2000 Chevy S-10 4wd actuator valve
139,000 MILES • 6 CYL • 4WD • AUTOMATIC
ALEXFAULKNER2294
do you know where the 4wd actuator valve is in my truck and how to replace it?
Dec 6, 2009 at 1:42 PM
  • 110,248 POSTS
The actuator is located on the transfer case. Basically, it is a bolted on electric motor that shifts the transfer case gears. Unbolt it and unplug the wiring to replace it.
Let me know if you run into trouble.
Dec 11, 2009 at 2:49 AM
