2000 Chevy S-10 2000 S10 Headlights
2000 CHEVROLET S-10
115,000 MILES • 4 CYL • 2WD • MANUAL
JOHNMINTZ
I am having trouble fixing my driver's side headlight. The low beam does not work. The high beam works fine. I tried to change the bulb but the same thing happened. Just to make sure, I tried a different bulb. Still no low beam. I made sure not to touch the glass on the bulb. Any ideas?
Jan 28, 2009 at 7:08 PM
S10OWNER84
I have an 03 S10 xtreme that gave me the same problem, simple fix, U kno the connector that u plug the bulb into? that needs to be replaced, advance auto parts or your local parts store will have one, just cut the old one off wire it back on and it will work good as new..
Feb 1, 2009 at 10:51 AM
