2000 Chevy S-10
2000 CHEVROLET S-10
CHEVYSOUL
Electrical problem
2000 Chevy S-10 6 cyl Four Wheel Drive Automatic
the right turn signal will not work but the running light in the rear does and it is all on the same bulb
Sep 24, 2010 at 11:38 AM
MADMIKE1735
  • 951 POSTS
is there any green corrosion in the bulb socket???? also, assuming the bulb is good, your problem may lie a bit deeper in the electrical harness.... do you have a plug for a trailer on this vehicle??? if so, check to see the condition of the wires where they T-ed into your factory harness.... let us know what you find.
Sep 24, 2010 at 11:43 AM
