1999 Chevy S-10 wire diagrams
149,000 MILES • 4 CYL • 2WD • MANUAL
RICK8672
i have a s-io and the engine was rebuilt and alot of wires are diconected from under i need a flow chart because half of the wires are positive half are negative and diconected the fual relay does not kick in thr manuel i have got is to unprecise on the wire diagrams so i need a flow chart to run all the lose wires back in place or a site to download the flow chart
Nov 7, 2008 at 4:05 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_0900c152800bffdd_1.jpg
This diagram should help you locate the fuel relay along with a few other major components. Your local Chevrolet dealer should be able to print off the diagrams for you. If this does not help then you can always purchase a repair guide that is detailed for electrical issues.
Nov 7, 2008 at 3:02 PM
