was putting new front wheel bearings in today. took the lugnuts off and tire wouldn't budge. had to put a 2x8 on the inside of the wheel and keep beating with a sledge and it finally came off, same for the other side also. put new bearings in and when I went to mount the tires they barely went on the studs. put the lugnuts on and went around them with an impact and they finally drew back ok. know it will be the same next time. these are the factory aluminum wheels that came on the truck when I bought it in 1999. any ideas or suggestions would be greatly appreciated. thanks
Dec 22, 2007 at 9:17 PM
