1999 Chevy S-10 oil gauge
200,035 MILES • 6 CYL • 4WD • AUTOMATIC
KRAMER_115
when the truck is cold it runs great however once it warms up any time I come to stop I lose oil pressure and my check gages light comes on. This is not a fluke being that it happens every time I drive my truck. I have had numerous feedbacks and would like to hear from someone who knows what it could be instead of guesses as to the problem. Is it the sending unit or the oil pump itself. If it is the oil pump could you tell me where it is located on my truck. And also my fuel pump is staying on for extended periods of time to where I have to actually remove the fuse to shut it off. Any input will be more hen helpful. ~Thanks~
Sep 14, 2008 at 9:09 AM
  • 75,988 POSTS
Could be the OPSU get it to run and remove the fuel pump relay did it stall?
Sep 14, 2008 at 9:20 AM
KRAMER_115
yes it stalls when the relay is removed
Sep 14, 2008 at 9:23 AM
  • 75,988 POSTS
Check the oil pressue with a mechanical gauge if oil pressure okay -Replace the OPSU
https://images.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_71.gif
Sep 14, 2008 at 3:11 PM
