1999 Chevy S-10 oil gauge
KRAMER_115
  • 1999 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 200,035 MILES
When the truck is cold it runs great however once it warms up any time I come to stop I lose oil pressure and my check gages light comes on. This is not a fluke being that it happens every time I drive my truck. I have had numerous feedbacks and would like to hear from someone who knows what it could be instead of guesses as to the problem. Is it the sending unit or the oil pump itself. If it is the oil pump could you tell me where it is located on my truck. And also my fuel pump is staying on for extended periods of time to where I have to actually remove the fuse to shut it off. Any input will be more hen helpful. ~Thanks~
Sunday, September 14th, 2008 AT 4:09 PM
Could be the OPSU get it to run and remove the fuel pump relay did it stall?
Sunday, September 14th, 2008 AT 4:20 PM
KRAMER_115
Yes it stalls when the relay is removed
Sunday, September 14th, 2008 AT 4:23 PM
Check the oil pressue with a mechanical gauge if oil pressure okay -Replace the OPSU
https://www.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_71.gif
Sunday, September 14th, 2008 AT 10:11 PM
