The oil pressure gauge started flailing back a forth first high then low then leveled out in a higher position than normal. Next day truck wouldn't start, all fuses where checked. Fuel pump not yet tested.Could it be an oil pressure swtch? If so , where is that located. I want to elliminate all possible other things before dealing with the fuel pump. I think there is only one fuel pump and it is in the tank!
Let us pray...oil pressure switch...oil pressure switch. pLease say it could be that.
Jan 21, 2008 at 8:57 AM
