1999 Chevy S-10 O2 Sensor
275,000 MILES • 6 CYL • 4WD • MANUAL
ZZORAG
My MIL is on and after scanning it the code came up as P0147 O2 sensor Heater Circuit Malfunction( Bank 1 Sensor3) Would that be located before or after the catalytic converter? Should it be replaced or could that code indicate a loose wire? Also is it easy to get at and fix?
Jan 26, 2008 at 12:46 PM
BLACKOP555
  • 10,386 POSTS
more then likely the sensor is bad.
it is located after the catalytic converter, last sensor on the exhaust pipe.
Jan 26, 2008 at 12:53 PM
