1999 Chevy S-10 Lines
96,000 MILES • 6 CYL • 4WD • AUTOMATIC
TRG728774
I have a 99 Chevy s-10. There is a line comming off the right front tire (not the actual brake fluid line) but another line that runs beind the brake shield and connects into a plug on the frame. My question is what is this line and what affect does it have if the line is cut?
Thank you
Todd Goodnow
Jan 5, 2008 at 7:22 AM
BMRFIXIT
  • 19,053 POSTS
[quote:90890f87de="trg728774"]Brakes problem
1999 Chevy S-10 6 cyl Four Wheel Drive Automatic 96,000 miles
Thank you
Todd Goodnow[/quote:90890f87de]
ABS
that’s the ABS sensor
its will effect your braking quality on quick stops and at ice wet sand surfaces
also it will shut off ABS system and traction control
Jan 6, 2008 at 12:03 AM
