[quote:65b970c862="CRAIGM"]Electrical problem
1999 Chevy S-10 4 cyl Two Wheel Drive Manual 117868 miles
WITH ENGEIN OFF HAVE CONTONUITY AT #2 INJECTOR DIS CONECT AT COMPUTOR AND GOES AWAY HOOK BACK UP AND ITS THARE AGANE CAN THE COMPUTOR BE RESET OR DO I NEED NEW[/quote:65b970c862]
ECM ground the injectors
but the relay supply the power
I don’t understand the problem that you are having
put I don’t think resetting computer will change its function
if you can elaborate on what you need may be I can help
Jan 5, 2008 at 11:56 PM
