1999 Chevy S-10 HEAD Gasket replacement
14,500 MILES • 6 CYL • 4WD • AUTOMATIC
STICKMAN7
Do you need to remove the water pump to replace head gasket or replace the head??
Mar 1, 2009 at 8:15 AM
BRIAN 1
  • 1,030 POSTS
no,but if the water pump has not been replaced before it might be good to replace it while you have it apart for piece of mind,if not you do not have to remove it for this repair.
Mar 1, 2009 at 10:06 AM
