1999 Chevy S-10 fuel
JEFFSTILT
Engine Mechanical problem
1999 Chevy S-10 6 cyl Four Wheel Drive Automatic
My truck will not start.. You can pour gas in the intake and it will run until the gas runs out.. The fuel pump is running and I have fuel pressure on the line.. I changed the fuel pressure regulator and it still won't run.. What can be wrong?
May 11, 2010 at 2:01 PM
2CARPRO JACK
  • 11,533 POSTS
How much fuel pressure do you have? that engine needs 60-66 psi to run.I hav eseen a ton of them make a little pressure but not enough to run the engine.Verify what pressure you have with a manual gauge
May 11, 2010 at 2:10 PM
JEFFSTILT
I checked the pressure and I have 63 to 64 PSI..
May 11, 2010 at 3:25 PM
2CARPRO JACK
  • 11,533 POSTS
Use a test light and probe every fuse in the truck, both underhood and under the dash.Sounds like the injectors arent hitting.
May 12, 2010 at 2:39 PM
