1999 Chevy S-10 Engine code
110,000 MILES • 4 CYL • 2WD • MANUAL
XTREMEMAN34
what will throw this engine code in a 1999 chevy s-10 xtreme 2 wheel drive 5 spd code is PO 137 its reading this message on my actron scan tool 02s ckt low volts 1 2
Apr 20, 2010 at 9:21 AM
HMAC300
  • 48,601 POSTS
there are 2 O2/s in your carone before th converter and one after. the one after is the one screwing up so check and see if it's one any good and not damaged or a wire broken. Or if it is getting good voltage........ it's probably bad though.
Apr 22, 2010 at 12:24 PM
