1999 Chevy S-10 clutch slips
10,700 MILES • 4 CYL • 2WD • MANUAL
JIMCROWELL
I recently replaced the clutch in my 99 chevy s-10. I drove about 50 miles and it started to the same thing before I replaced it. It started slipping. The clutch pedal comes all the way to the top with no play. I can shift it into gear but it won't move. The clutch, pressure plate and release bearing were replaced. It seems to build up pressure as I drive.
Jim Crowell
Jun 14, 2010 at 12:55 PM
HMAC300
  • 48,601 POSTS
check for a bent/cracked/or broken release arm or the rod going from the slave to the arm is bent or worn out.
Jun 16, 2010 at 4:33 AM
