1999 Chevy S-10 battery? alternator?
1999 CHEVROLET S-10
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARTY1115
The alternator and battery have been replaced within the past two weeks and it is still a toss up as to whether the car will start or not (usually not). It will run with a jump. The last tow truck driver suggested that the battery I purchased is no good but could not give specifics. Are there really any BIG differences between batteries?
Jul 7, 2010 at 1:49 PM
INTERNETMECHANIC
  • 700 POSTS
Use a digital multimeter across the battery posts, everything turned off. The generic spec for a fully charged battery is 12.6 volts. If the battery is down, take it off and get it charged, not a good idea to let alternator try to charge it.
Also, with the meter leads at the battery posts, have a helper turn the key to crank, watch the voltage, it shouldn't drop below 9 or 10 volts. You have to do testing when the problem is ongoing. When the problem occurs, did you try cranking in neutral? The purple wire at the starter solenoid S terminal should be hot with the key in the crank position, check when the problem is ongoing.
Jul 8, 2010 at 8:46 AM
