1999 Chevy S-10 altinater
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
DPELZEL
i was towing a pontoon boat back from a lake in ohio when i nocticed the volt gauge was low around 11 volts it ran ok to get the boat home, i took the truck home then turned it off then started it back on and it started ok but the volt gauge was still low around 11-12.5 volts . do you think the alt is going out? thank you
Aug 3, 2010 at 2:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
could be or belt may be slipping a bit. can take vehicle and have charging system tested for free at most local auto part stores.
Aug 3, 2010 at 2:42 PM
