1999 Chevy S-10
1999 CHEVROLET S-10
119,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAPATONY50
My right side brake light goes dim when i press the brake peddel. The blinker also goes fast and the side lights and the back up lights blink. I have replaced the bulbs and still the same results.
Oct 27, 2010 at 11:34 AM
HMAC300
  • 48,601 POSTS
check aroundthe taillightfor a groundwire, it is making poor or nocontact. trace it back and it may be on the frame under the bed, clean it and try your blinker then. it should work ok. usually that is the case unless the wire is broken then it has to be repaired.
Oct 28, 2010 at 12:19 PM
