1999 Chevy S-10
18,000 MILES • 4 CYL • 2WD • MANUAL
TIGGO
i have blead the brakes and refilled with new brake fluid and the brake pads are still in almost brand new condition as soon as i touch the brakes they almost instantly drop to the floor and i just hope that they manage to get me stopped they also take a while to come back up after i take my foot off of it they dont even have the power to lock up a little on gravel or grass even just tryin to figure out the problem thanks
Oct 20, 2010 at 7:17 AM
  • 75,988 POSTS
Overall the brake master cylinder or replace it-if its not coming from the ABS unit-
Oct 20, 2010 at 9:45 AM
TIGGO
I have been told that it could just be the brake booster do u think I could just be this?
Oct 20, 2010 at 9:50 AM
  • 75,988 POSTS
Do this before you start it up-pump the brakes till it gets hard and then start it up the pedal shoud drop slightly if the booster is doing its job
Oct 20, 2010 at 10:25 AM
TIGGO
No they don't drop hardly at all just very very slightly nothin like they used to before my brakes got messed
Oct 20, 2010 at 2:04 PM
  • 75,988 POSTS
If you're stepping on the brakes constantly after you have pump it a few times while the engine is running and its sinking gradually-it points to the master cylinder unless you have a leak somewhere. Good Luck
Oct 20, 2010 at 5:33 PM
