1999 Chevy S-10
ELAD60
Electrical problem
1999 Chevy S-10 4 cyl Two Wheel Drive Manual
i have a new battery but the gauge in the dash is showing low voltage.also the battery icon stays on all the time.thanks,dale burkett
Apr 1, 2010 at 5:12 AM
TWOSTEPPER
  • 42 POSTS
I'd have to use a voltage tester across battery posts, to check for full charge. Battery connections good on both ends? I'd also have to check the charging system. The instrument cluster wiring, might have an issue?
Apr 1, 2010 at 5:18 AM
