1999 Chevy S-10
10,400 MILES • 4 CYL • 2WD • MANUAL
SMITTY44
My S-10 has been acting up for a little while mostly when it is raining or damp outside. It will jerk like it wants to stall at low rpm's after shifting;but not excessively low, I have shifted near redline and this still occurs. When it has been running for a while this will disappear and it never happens on a sunny dry day. About 2 days ago the truck wouldn't start and I had the starter replaced. Now it turns over fine but runs rough and has stalled. It feels like it is a fuel delivery problem to me and I have been through a tank of gas several times since I started. I pulled the trouble codes and it listed the Intake O2 sensor and the crankshaft and camshaft position sensors. Is this just an electrical problem that can be fixed by replacing the sensors or is there more to this? Thanks.
Nov 30, 2009 at 10:00 AM
SWILLIAMS
  • 597 POSTS
Put a good scan tool on it and watch the live data from the sensors. That will tell you what the problem is.
It could be just one sensor causing the problem BUT it could also be a bad ground or power connection in the harness or even in the ECM itself. Hard to say without actually watching what they are doing.
Dec 6, 2009 at 11:01 AM
