air blows thru dash vents only . will not blow thru defrost or floor vents
Oct 25, 2009 at 9:05 AM
✓Experienced Mechanic
You are looking for a vacuum leak. The vent doors are actuated by vacuum. Check under the dash and the hood for leaks. Many times, you will hear a hissing sound where it is leaking from.
