HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
S-10
Drivetrain
Transmission
Symptoms
Not Shifting
SPONSORED LINKS
1998 Chevy S-10 wont shift auto, will shift manually
PUPILJJ
MEMBER
1998 CHEVROLET S-10
4 CYL
2WD
AUTOMATIC
125,000 MILES
Shifts fin 1-2 but I have to shift up into 3rd and O.D.?
Monday, January 25th, 2010 AT 10:08 AM
DOCFIXIT
MECHANIC
Check engine light on? Will it down shift once in OD and you slow?
SPONSORED LINKS
Monday, January 25th, 2010 AT 12:37 PM
PUPILJJ
MEMBER
Engine light is on, shifts down fine but I have to put shifter back in 2nd and start shifting up again from a stop. Is there anyway to test a PCM?
Monday, January 25th, 2010 AT 1:43 PM
DOCFIXIT
MECHANIC
Go to Auto Zone, Advance ect have codes read then post will advise
Monday, January 25th, 2010 AT 1:48 PM
Please
login
or
register
to post a reply.
Related Transmission Not Shifting Content
Shift Problems
I Have A 1998 Chevy S10 2.2 Auto. Whenever It Senses A Load Such As Climbing A Grade Or Passing The Tranny Will Attempt To Downshift But...
Asked by
gary phillips
3 IMAGES
1998
CHEVROLET S-10
1998 Chevy S-10 Will Not Shift Gears
Transmission Problem 1998 Chevy S-10 4 Cyl Two Wheel Drive Manual 130.00 Miles I Had Just Replaced The Cluch Onmy 1998 Chevy S10 About...
Asked by
daveyduke
1 ANSWER
1998
CHEVROLET S-10
4l60e Has Problem Shifting In Drive
I Have A 98 S10 Zr2 And When I Place The Tranny In Drive It Has No Power And Accelerates Slowly, But If Shift Down To 1 And Up It...
Asked by
ted mitchum
1 ANSWER
1998
CHEVROLET S-10
1993 Chevy S-10 Will Not Shift Into 4 Hi Range
The Car Has An Electronic Switch For Shifting In And Out Of 4x4. It Will Go Into 4lo, But Not 4hi. I Had The Module Replaced And It Worked...
Asked by
revman2007
1993
CHEVROLET S-10
Not Down Shifting Properly
I Have A 1994 S10 Blazer. Two Wheel Drive, 4.3 Vortec V6, Auto Trans. 93,500 Miles. I Had The Trans Rebuilt About 2000 Miles Ago....
Asked by
I_hate_my_truck
1 ANSWER
CHEVROLET S-10
VIEW MORE
SPONSORED LINKS
Transmission Speed Sensor Replacement Honda
Transmission Turbine Sensor Replacement
Pilot Bearing Replacement
Online car repair manuals
