1998 Chevy S-10 truck trouble
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
POW3LL
my truck will have power failure after 10 minutes of driving it just putters at about 5 mph it is not the cat converter i pulled that last night and you can see right through it
Dec 30, 2009 at 9:14 AM
  • 110,248 POSTS
Have you checked fuel pump pressure? Has the check engine light come on?
Jan 2, 2010 at 10:15 AM
POW3LL
the check engine light is on how do i check fuel pump pressure
Jan 3, 2010 at 6:01 AM
  • 110,248 POSTS
Here is a how to for checking fuel pump pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
As fof the check engine light, you need to have that checked with a scanner. Most nationally recognized parts stores will do it for free, so I suggest having that done. Let me know what you find.
Jan 3, 2010 at 6:06 AM
