1998 Chevy S-10 Transmission question
169,345 MILES • 4 CYL • 2WD • AUTOMATIC
ANDYDEUCE
When my s10 gets hot the transmission wants to kick out of 4th gear/overdrive. Runs fine when cold. Is there a hot fuse somewhere that could be malfunctioning or some other problem?
Jun 30, 2008 at 4:55 AM
TRUEFIRE04
  • 35 POSTS
i had a problem kinda like this....but i couldnt get the thing to shift out of 2nd....so i changed the solinoids, did nothing....ended up taking it to the dealer $700. later found out the ecu was bad. the 700 also included the rental.
Jul 2, 2008 at 7:06 AM
