1998 Chevy S-10 speedometer issues
100,200 MILES • 4 CYL • 2WD • MANUAL
JMOLTENIO
the speedometer shows to be about 10 mph below actual speed. the dash shows all lights illuminator( check eng, highbeam, tow/haul, seatbelt, service 4x4, etc.)
t5he truck also does not respond to diagnostic tests through the obdii port.
what could this possibly mean
Mar 12, 2009 at 11:52 AM
FRANK2009
  • 10 POSTS
When U run diagnostic tests and u don't think the computer is responding.
Remove a battery cable. Wate a bit to let the computer clear itself. Then drive for a while and try again.
If still no reply from the computer and everything other then your speed being off is ok.
Check your tires size,r the ones on now different.
This could make a different in your speed.
Hope this helps
Frank
Mar 12, 2009 at 10:32 PM
