1998 Chevy S-10 Soft brake pedal
1998 CHEVROLET S-10
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHUMMEL
My brake pedal suddenly is soft and doesn't pinch the calipers until it's pushed pretty far down to the floor.
When I push the pedal all the way down, the brake warning light comes on. Not the ABS light, but the other one.
I checked all over for leaks in lines but couldn't find any. And the master-cylinder reserve isn't low on fluid.
I'm assuming it needs a new master cylinder. This is the first auto that I've owned with ABS.
Is there anything I need to know special about replacing a master cylinder with ABS brakes? Is there some air trap thing that could happen?
Thanks.
Dec 18, 2008 at 12:13 PM
DOCFIXIT
  • 18,828 POSTS
Your right master replace the sam way no special deal. R&R bleed be sure and bench bleed
Dec 19, 2008 at 2:27 AM
