1998 Chevy S-10 sensor
127,000 MILES • 4 CYL • 2WD • AUTOMATIC
RUDY209
how do i replace MAP sensor on my s10 2.2 engine
Jul 28, 2010 at 12:08 PM
  • 75,988 POSTS
Service and Repair
https://images.2carpros.com/forum/automotive_pictures/12900_m_1.gif
https://images.2carpros.com/forum/automotive_pictures/12900_m1_1.gif
Removal Procedure Remove the electrical connector. Remove the attaching screw (1). Remove the bracket (2). Remove the Manifold Absolute Pressure (MAP) sensor (3) from the intake manifold (4). Installation Procedure Install the MAP sensor (3) into the intake manifold (4). Install the MAP Sensor bracket (2). Install the the attaching screw (1). Tighten the attaching screws to 4-6 N.m (35-53 lb in). Install the electrical connector. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Jul 28, 2010 at 1:24 PM
