1998 Chevy S-10 SEALING THE TIMING CHAIN COVER
180,000 MILES • 4 CYL • 2WD • MANUAL
DRUQUEAL
My friend replaced my timing chain, and now it is leaking oil around the timing chain cover. The gasket sealer he used did not seem to hold. Can we put a sealer on the outer edges of it to keep it from leaking with-out taking it apart and redoing it ?
Apr 11, 2010 at 11:38 AM
HMAC300
  • 48,601 POSTS
you can try puting RTV on the outside but more often than not you'll have to pull it off and fix it correctly....
Apr 12, 2010 at 10:22 AM
