1998 Chevy S-10 rod bearing failure
150,000 MILES • 4 CYL • 2WD • MANUAL
KALIANNEE
Had engine analyzed ,results were mosfire #2 cylinder. Possible causes were vacuum leak, or bad catalyitic converter. Car good had to drive about 100 miles to get home, and engine went bad. Had engine pulled out and I tore it dowand . #2 rod bearing was pounded. put in used engine and used all old electronics, after a few mile CE light came back on. Could my bearing failure be due to electronic problem?
Oct 8, 2009 at 9:31 PM
  • 110,248 POSTS
The bearing wouldn't be causing a sensor to go bad. Have you had the computer scanned?
Oct 17, 2009 at 10:10 AM
