1998 Chevy S-10 REMOVING HVAC MODULE
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHADETREE1337
I am trying to remove my HVAC module to replace my heater core. I have already removed the dash and removed the bolt inside the blower motor resistor hole. Apparently there are 3 stud bolts running through firewall from engine side holding the HVAC module on. The top one at center of firewall is no problem. The two on bottom appear to be a nightmare to access. Not knowing anything about this, there appears to be 3 possibilities to access these 2 lower stud bolts: 1) remove black plastic shroud on engine side that holds blower; 2) pull front passenger tire and fender well; 3) drop exhaust from manifold and come up from bottom. Any suggestions on the best way to tackle this problem?
Mar 19, 2010 at 6:54 AM
  • 75,988 POSTS
Hi Shadetree1337, Welcome to 2carpros and TY for the donation See below-sorry its too long but it'll do the job
https://images.2carpros.com/forum/automotive_pictures/12900_h1_12.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_h2_11.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_h3_4.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_h4_4.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_h5_2.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_h6_2.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_f9_2.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_f10_2.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_f11_2.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_f12_2.jpg
Mar 19, 2010 at 11:10 AM
