1998 Chevy S-10 No (very little) Brakes
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
NOMAD943
My brakes were working fine until one day when I was forced to do a full panic stop from about 35 mph.
The truck stopped perfectly, but after that the pedal basicaly goes right to the floor with only a little catch at the very end coming from the rear brakes.
The obvious problems did not manifest. The fluid level remained up. No leaks were detected anywhere. I bled the lines but basicaly found no air.
As a last gasp I gambled and changed out the master cylinder ... same situation exactly.
When the truck is not running there feels like there is some pedal, but as soon as I start it up ... right to the floor .... any ideas?
May 7, 2009 at 1:11 PM
NOMAD943
To answer my own question for anyone who encounters a similar problem:
I found another similar question on this site which mentioned the possibility of the front rubber brake lines "expanding" when the brakes were applied and even though I didnt observe any actual expansion in the lines myself, I replaced them anyhow.
Problem solved, total cost 26$ .......
Now if only I could return that master cylinder ... lol
Aug 27, 2020 at 11:30 AM
