1998 Chevy S-10 no rear brakes
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
TMAYER29
I have a 1998 chevy s-10,180k miles ,disc in front drum in rear. I changed pads in front 6 months ago. I backed out of garage, gently pumping brake pedal, because brakes were very stiff. Then the brake pedal just went to the floor. i have no rear brakes. any ideas or suggestions please!
Dec 10, 2008 at 11:59 AM
SWILLIAMS
  • 597 POSTS
Could be a failed master cylinder, broken brake line, failed wheel cylinder. If you're not losing fluid then it is probably the master cylinder.
Dec 12, 2008 at 2:15 PM
