1998 Chevy S-10 ignition wires
JOHN HEATON
Electrical problem
1998 Chevy S-10 4 cyl Two Wheel Drive Manual
Is there a trick to removing the spark plug wires from the spark plug or do you just pull ive tried a straight pull but they did not come off and I don't want to break anything
Oct 2, 2009 at 3:46 AM
SEANS10
  • 9 POSTS
i have the same 98 s10 as u. u will need to take off the a/c off then u can get to the plugs. but dont just pull on them. u need to twist the pulg wire then pull but not to hard. the wire should come right off
Oct 2, 2009 at 5:29 AM
