1998 Chevy S-10 help! seemingly impossible to shift gears.
1998 CHEVROLET S-10
146,000 MILES • 4 CYL • 2WD • MANUAL
OUTLAW106
the problems started after an ABS light lit up, the speedometer is erratic now.. I have to use two hands to shift or start in gears.. today when I started in 1st it launched forward and stalled out completely. I need my little truck or I will be out of work this week. :( also the clutch pedal feels like less work than before..?
Mar 28, 2010 at 2:19 PM
HMAC300
  • 48,601 POSTS
check the operation of your clutch, usually a shift problem is due to low oil in trans or the clutch isn't working right. If the ABS light is on you've got something wrong, best to get a scan on it to find out what the problem is.also if your speedo is erratic, it's either the speed sensor or teh speedo itself. if you get the truck scanned it should show up on the scan.
Apr 2, 2010 at 12:19 PM
