1998 Chevy S-10 gauges
126,000 MILES • 4 CYL • 2WD • MANUAL
ROMANOFF
all of a sudden ALL of my gauges dropped to 0 and every once once and a while they will register but then immediately drop again. can you help me?
Mar 3, 2010 at 3:29 AM
JDL
  • 16,098 POSTS
hi, I'd start by checking the fuse circuits to the instrument cluster. Use a testlite, check that the fuse circuits are hot when they should be. Go from there. If you have any manufacturer specific trouble codes, that might point you in the proper direction.
If you need wiring diagrams, be glad to help.
Mar 3, 2010 at 3:47 AM
