Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
S-10
Fuel System
Fuel Pump
Fuse
1998 Chevy S-10 fuel pump not getting power
1998 CHEVROLET S-10
132,513 MILES • 4 CYL • 4WD • AUTOMATIC
IMAANDRUS
MEMBER
1 POST
I have recently changed my fuel pump, and it's not getting any power. I've checked all the fuses they are good. What could be the problem?
Feb 20, 2009 at 5:42 AM
JDL
Experienced Mechanic
Hello, did you check the ecm B fuse in the underhood electrical center? Not only check the fuse, check that the fuse circuit is hot.
With the engine cranking, is there an injector pulse? Do you have spark at the plugs?
Feb 20, 2009 at 7:36 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
