1998 Chevy S-10 Fuel Pump issue?
1998 CHEVROLET S-10
MHENSCHEL
Engine Performance problem
1998 Chevy S-10 6 cyl Two Wheel Drive Automatic
Recenly my truck just stopped running. Hard crank, but seems like no fuel to turn her over. After sitting for about an hour (while I went and purchased a new fuel pump) the truck started.
This has now happened again, however, not starting at all.
I suspect the fuel pump, although I'm not sure that it would have started after a waiting period if this was the case. I plan on checking the fuel pressure, when I can figure out how.
Fuses have been checked and are ok. Could this be a module / electrical issue. I'd like to try all options before dropping the gas tank.
Thansk for your assistance.
Apr 27, 2010 at 5:40 AM
Power the fuel pump from the battery if it comes on-check and test the fuel pump relay
Apr 27, 2010 at 5:46 AM
