1998 Chevy S-10 failed emissions test
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
JD70CHALLENGER
The fault codes are
p0452 evap control system pressure sensor low input
P0453 evap control system pressure sensor high input
can you tell me what i should look for or what part or parts maybe i should replace?
Feb 6, 2008 at 5:32 AM
2CARPRO JACK
  • 11,533 POSTS
You will need a scanner to monitor the voltages for the sensor. It ison top of the fuel tank.COuld just be a bad sensor....... any previous work or anything done to the truck?
Feb 7, 2008 at 3:55 AM
JD70CHALLENGER
thanks for your reply no work done to vehicle. i do not have access to a scaner. is it worth replacing the sensor even though i realize it's hunting and pecking?
Feb 7, 2008 at 6:22 AM
2CARPRO JACK
  • 11,533 POSTS
Might be since it said both ranges were off on the sensor
Feb 7, 2008 at 9:58 AM
