1998 Chevy S-10 engine missing
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHEETSYZ
I have a 98 s10 4.3 engine and i can start it up and drive it down the road and then after about 5 miles if i try to accelerate the truck will fall on its face and not let me give it any gas. Now as i am driving if i put the car in nuetral and turn it off and wait 5 seconds and then start it back up while driving i can accelerate for maybe a few miles. When i accelerate i can barely press on the gas pedal. It almost seems that when i turn the truck off it resets it, what could my problem be. I have given it a tune up checked the cap and roter, the map sensor, the exhaust.
Thanks Scott
Jul 15, 2008 at 10:39 AM
SWILLIAMS
  • 597 POSTS
Check the fuel pump pressure AND flow rate. Also check the fuel filter as a clogged filter can cause this as well.
Jul 16, 2008 at 8:26 AM
