HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
S-10
Engine
Symptoms
Oil Leak
1998 Chevy S-10 engine
ROBERTALMODOVAR
MEMBER
1998 CHEVROLET S-10
6 CYL
2WD
MANUAL
137,000 MILES
Water leaking out of engine pully area how can I seal it
Saturday, December 29th, 2007 AT 10:17 PM
BMRFIXIT
MECHANIC
By replacing the water pump
most likely its the water pump and I don’t think any one on the web will or should recommend a sealer
SPONSORED LINKS
Sunday, December 30th, 2007 AT 12:18 AM
Please
login
or
register
to post a reply.
Related Engine Oil Leak Content
1998 Chevy S-10 Oil Leaks
Hello, I Am In Desperate Need Of Advice. I Just Purchased This Vehicle Used And Have Found Several Problems. The Seller Is Offering To...
Asked by
epa8310
1 ANSWER
1998
CHEVROLET S-10
GUIDE
Engine Oil Leak
A car engine uses motor oil to lubricate the internal moving parts of the engine such as crankshaft, rod bearings, pistons and valve train. This oil is controlled from...
First Off I Have A Lot Of Oil Leaking
I Have A Few Problem Areas With My Truck And Would Love To Know If These Need To Be Fixed Now Or Will It Hold In There A Bit. I Have A...
Asked by
JOHNNIEMATHEW
1 IMAGE
1998
CHEVROLET S-10
1993 Chevy S-10 Oil Leak Near Dipstick And Oil Filter...
Ok, I Know This Truck Has Almost 450,000 Miles On It With It's Original Engine And Transmission, But I'm Stumped. A Couple Of Months Ago...
Asked by
foggergrad07
1993
CHEVROLET S-10
Oil Leak And Smoke
Massive Oil Leak And Lots Of Oil Smoke From Under Hood. Used Cylinder Head Installed At 93,000 Miles. Cylinder Three Spark Plug Is Oiled Up...
Asked by
Billyho203
2001
CHEVROLET S-10
Oil Leak But Only On The Right Side Of The Motor.?
My 2002 S10 Crew Cab Has A Leak But The Oil Is Coming From The Right Side Down To The Oil Drain Plug And I Cant Figure Out What Is Causing...
Asked by
cherokeez71
2002
CHEVROLET S-10
VIEW MORE
SPONSORED LINKS
Crankshaft Main Seal Replacement - Front
Crankshaft Seal Replacement - Rear
Cylinder Head Gasket Blown Symptoms
Online car repair manuals
