1998 Chevy S-10 driver door
RIXBAK
Electrical problem
1998 Chevy S-10
Key on and radio playing, shut off engine but radio continues playing untill the passenger door opens then radio shuts off...good. The drivers door does not shut the radio off, why, where should I look and what should I look for.
updated 7-27-09
The interior light does not work when the drivers door is open. I tried to remove the interior door panel but got stuck at the interior door handle. You mentioned 'switch', where would this be located and is it repairable or replaceable?
Jul 19, 2009 at 9:38 AM
JMALECKI
  • 118 POSTS
Hello
Most likely it is the door switch, does the interior light go on when the drivers door is opened?
John
Jul 25, 2009 at 3:45 PM
JMALECKI
  • 118 POSTS
The switch should be in the front of the door jam and the door closes against it.
John
Jul 27, 2009 at 2:46 PM
