1998 Chevy S-10 Door
LYKJPC
Interior problem
1998 Chevy S-10 4 cyl Two Wheel Drive Automatic
How do i take the inside of the door off to replace the speakers
Jan 18, 2009 at 3:40 AM
BRIAN 1
  • 1,030 POSTS
Remove the door upper trim moldings.Remove the door handle bezel.Remove the window regulator handle, if equipped.Remove the power window switch, if equipped.Remove the trim panel screws from the armrest.
Remove the screws that retain the door trim panel to the door.
Use the J 38778 in order to release the door trim panel retainers.
Remove the door trim panel from the door.
post back with any other questions
Jan 19, 2009 at 2:32 AM
