1998 Chevy S-10 DISTRIBUTOR
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
TONTOBOBBY
NEW DIST.TIMING IS OFF.TDC ON #1 CYLINDER,ROTOR MARKS POINTING TOWARDS #1.CRANKS ALL DAY BUT NO FIRE.HELP...........?
Aug 26, 2010 at 6:09 AM
WRENCHTECH
  • 20,760 POSTS
The timing is not adjustable on the engine. When you turn the distributor, you are changing the rotor and injector synchronization. You actually need a professional scan tool to monitor the offset spec to get it set to zero. Here arde the initial alignment marks when first installing at TDC compression. Mark #1 is for the 4.3
https://images.2carpros.com/forum/automotive_pictures/561653_distributor_alignment_00_43_1.jpg
Aug 26, 2010 at 6:26 AM
