1998 Chevy S-10 Compressor clutch not engaging
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
IROBERTG
It all started when I replaced the Battery,,
Seems like the next day I couldn't get any cold air. I checked the fuses and relay they are fine.. What the heck,,
Jan 5, 2009 at 11:49 AM
  • 110,248 POSTS
Are you getting power to the clutch?
Jan 15, 2009 at 12:41 PM
IROBERTG
No, I have no power to the clutch.
Jan 16, 2009 at 10:14 AM
  • 110,248 POSTS
You need to work back looking for power. Check the relay...
Jan 16, 2009 at 2:16 PM
IROBERTG
I checked the relay,,, actually I swap out the relay with the horn relay, and the horn still worked,, so just assumed the A/C relay was good... I guess I'll start from the plug and work backward. I have had a problem with pack rats. eating through vac. hoses..
Thanks for the info, and your time.
I thought maybe there was something I was missing.
Thanks again,,,
Jan 17, 2009 at 1:25 AM
IROBERTG
Hey guy's spent most the morning chasing down a solution..
Wirng is all good, I believe that I am low on R-134a.
After chasing wires I finally started the truck and jumped across the contacts of the cycling switch. the clutch engaged. Still blows warm air after 5 min.
I'm not clear on which tap is the low side,,Is it the one on the accumulator???
Thanks again for your help...
Jan 18, 2009 at 7:31 AM
