1998 Chevy S-10 Clutch Problems
193,000 MILES • 6 CYL • 4WD • MANUAL
CJONES29
I have a 98 Chevy S10 ZR2 4x4. I have been adding brake fluid everday just to pump up my clutch to drive it. Once I have filled the Clutch Master Cylinder and pumped up the clutch its fine. No leaks and the clutch doesn't leak down. If it sets overnight I have to do the same thing again. I replaced the Slave Cylinder about 4 years ago and the master cylinder. The only difference was that I bought the slave cylinder from General Motors and my master cylinder from a local parts store. When the slave cylinder went out I didn't have a clutch period. Could it just be my master cylinder going bad and not my slave cylinder?
Jul 21, 2010 at 11:24 AM
  • 75,988 POSTS
If you have to do that everyday double check for leaks that fluid is going somewhere
Jul 21, 2010 at 11:31 AM
