1998 Chevy S-10 brake line replaced
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOMHEAGERTY
I had a broken brake line. I fix it and there is no leaks. The front brakes are fine. The back brakes are still not working right. Is there a re set on the abs box anywhere? When I hit the brakes it makes a nosie and the pedal jumps.
Jan 5, 2010 at 9:23 AM
DOCFIXIT
  • 18,828 POSTS
Could be two thongs if broken line in rear then combonation valve has shut off flow to rears. will be reset under rubber cup on one end. other is if air got into ABS servo then it has to bleed by a scnner.
Jan 6, 2010 at 2:55 AM
